It has been over half a year since the last keyboard project was released, and it's high time for some adjustments and improvements.
With the popularity and widespread use of 3D printing, I have redesigned the appearance to minimize unnecessary supports during the printing process, making it easier to print. The color scheme can be freely customized to present an even better effect.
We plan to support two different shapes of screens: rectangular and circular.
For the code, we plan to start updating from CircuitPython 9.x, while also supporting other frameworks such as Arduino and MicroPython.
To facilitate production and assembly, the circuit board has been simplified by removing redundant components and reducing the number of PCBs to just one. Additionally, some circuit modifications have been made, but the relevant pins remain compatible with previous designs.
Drawing inspiration from the C language implementation of tinyflap, I successfully developed a Flappy Bird game utilizing CircuitPython. The debugging phase proved to be unexpectedly seamless, enabling me to swiftly create an initial prototype of the game.
The ground and clouds were drawn using the adafruit_display_shapes lib, whereas the bird and pipes were implemented directly using images.
Primarily, I wish to sincerely thank PCBWay, a leading entity in the industry, for its perceptive vision in identifying the potential of my project and extending substantial backing. Your sponsorship has transcended material provision by equipping me with superior-grade, precision-crafted PCB products that have been instrumental in facilitating seamless advancement during the R&D process.
Throughout our cooperative engagement, the dedicated technical team at PCBWay has upheld a stringent attitude and provided efficient services, guaranteeing faultless precision at each juncture, thereby significantly boosting my operational efficiency. The outstanding product quality and considerate customer service you deliver have undoubtedly been crucial factors contributing to achieving key developmental milestones in the project.
The testing process has been largely smooth, during which we did identify a minor design oversight where the LDO (Low Drop-Out) section was not provided with a stable control signal, leading to an inability to completely shut down the system. However, this issue is relatively easy to rectify; it can be resolved by shorting two pins as indicated in the diagram. Currently, we are using CircuitPython version 8.x and have confirmed its successful operation. In the coming days, I will commence work on porting to version 9.x.
A charging indicator LED has been integrated onboard, facilitating the observation of the charging status.
