I have designed a PCB to use in My rc planes and drones. This card is supposed to;
- Can drive up to 6 DC motors with TB6612FNG,
- Able to drive up to 6 servo motors,
- Can read PWM signals coming from outside,
- Can be directly connected to lipo battery.
Required Components;
- Power Connector (XT60)
- Microporcessor x3 (Arduino Pro Mini)
- DC Motor Driver x3 (TB6612FNG)
- Connectors x6 (KF127-5.0-2P)
Order Your PCB From JLCPCB
For that, you just have to go to JLCPCB, (https://jlcpcb.com/HAR/) and click on the “QUOTE NOW” button. JLCPCB (ShenzhenJLC Electronics Co., Ltd.), is the largest PCB prototype enterprise in China and a high-tech manufacturer specializing in quick PCB prototype and small-batch PCB production.
You can order a minimum of 5 PCBs for just $2. To get the PCB manufactured, upload the Gerber file you downloaded in the last step. Upload the.zip file or you can also drag and drop the Gerber files. After uploading the zip file, you’ll see a success message at the bottom of the file that is successfully uploaded.
You can review the PCB in the Gerber viewer to make sure everything is good. You can view both the top and bottom of the PCB. After making sure our PCB looks good, we can now place the order at a reasonable price. You can order 5 PCBs for just $2 but if it’s your first order then you can get 10 PCBs for $2. To place the order, click on the “SAVE TO CART” button.
In my experience, finding a reliable DevOps service can be a bit of a challenge. But I recently stumbled upon a gem! This DevOps services has really changed my perspective. Their end-to-end solutions have drastically improved the efficiency of my operations. I've noticed a significant reduction in downtime and faster releases.
