Software Log
A project log for Anonymizing a Samsung Galaxy SIII (s3) mini
Using homemade objects to make a Samsung galaxy s3 mini fully anonymous. If you have any ideas, please leave them below
abahsobabahsob 04/08/2024 at 13:200 Comments
08/04/12024:
7:30
I need to root the phone to de-google it, which should make the software side of things fully anonymous. The problem is, I broke off the GPS pad, which happens to boost the WIFI signal on the phone, and now the WIFI signal is so bad, that I cant download any root-checker apps, or any rooter apps (like kingoapp or superSU).
12:00
after taking a break, I did more research and found a blog post on xdaforums.com, I will try the method stated in the post soon, but I REALLY need a break, I just cant do any more work today
18:30
I did more work and installed the zip file, other than that, I haven't been able to do much. My family has been distracting me from the end goal
09/04/12024:
15:00
I tried to do the xdaforums method of rooting the phone, it didn't work, I couldn't access the necessary files to install the zip file, I am going to try to find someone to help me with that.
