Supplies
A project log for 1.28" Screen With ADC
I want to make a thermometer and a weight scale using some sensors and ESP32 board.
makerfabsMakerfabs 04/09/2024 at 01:120 Comments
The 1.28" screen have 2 standard GPIO and I2C bus, which colud be used as ADC.
When the lever moved from one side to the other, its output voltage ranges between 0 V to the VCC you applied.
