Bye Bye Fingernail
A project log for Bootstrap 3D Printer
Bootstrap: A large volume 3d printer that can be built at home without requiring any custom 3d printed or machined parts.
es-pronkE/S Pronk 04/30/2024 at 22:580 Comments
It took me a good 40 minutes and a part of my fingernail, but I managed to abuse a standard NEMA17 mount to fit M5 bolts at the spacing required for the carriage, using a handdrill, pliers and a screwdriver.
 Installed it
And the first extruder is in place... Now I still need to figure out where to install the BLTouch. Probably going to mount an L bracket between the motor and the extruder. <-- scrap that...
4 tie wraps + 2 pieces of a wooden fork as a spacer. That BLTouch is going nowhere...
