• 1
    ENCLOSURE : 3D Printing
    Print the two stl files : base and top
  • 2
    ELECTRONIC ASSEMBLY
    Individually prepare the components :
    • Solder 2*6 headers on the ADAFRUIT QTPY RP2040 (pins A1--TX and RX--GND)
    • Solder 2 headers on the 3.5mm jack breakout (pin TIP ans SLEEVE)
    • Cut two platsic pins under the tactile switch, cut two pins on the switch
    • Cut two wires : 3.5cm and 4cm
    Solder the components :
    • Solder the ADAFRUIT QTPY RP2040 on the protoboard : B1 to B6 and F1 to F6)
    • Solder the tactile switch on the protoboard G1 and G3
    • Solder the 3.5mm jack breakout (F11 and E11)
    • Connect A3 QTPY's pin to RING02 with the 3.5 cm wire, solder
    • Connect GND QTPY's to TIP with the 4cm wire, (J1- J11), solder
    Cut of the excess lenght of the pins
  • 3
    MECHANICAL ASSEMBLY
    • Insert the electronic onto the base part
    • Snap the two parts of the enclosure
