Currently used in the Kunsthaus Wien
A project log for IRremoteSync
Use an Arduino to sync as many media players or DVD players as you want.
lumbriclumbric 08/03/2014 at 16:240 Comments
Currently an IRremoteSync is used in the Kunsthaus Wien in the exhibition "SHOEting Stars":
http://www.kunsthauswien.com/en/exhibitions/current
(I assume this link will point to another exhibition in future.)
Short videos (10 seconds) are played on two screens using built-in media players. The videos have exact same length, but also if you start both media players at the same time, after some while the two loops drift apart. Every hour the IRremoteSync sends IR commands stop and after a short delay start to keep the two independent video loops synchronized.
