Battery Sourced
A project log for Star Trek Communicator Badge
In the true spirit of Star Trek, this communicator badge is completely autonomous, while fitting in the form factor of an original badge
joeJoe 02/27/2017 at 05:280 Comments
I found a battery that just barely fits in the cavity space I have available, maximizing battery capacity. It is a 150mAh battery from Adafruit: https://www.adafruit.com/products/1317
Just one minor detail though... I forgot to add a power switch on the board. For the first prototype I will have to manually add one in-line with the battery cable. Oops!
