Results Part1
A project log for Mona Lisa ParaFoil
A lightweight compact fabric/stiffer material Parafoil underslung is a raspberry pi for control and camera feed. See notes this has evolved
slncioSlncio 03/05/2017 at 20:220 Comments
Tuns our its about 15 grams that the little crazy flie can lift! I rigged up a little tube and popped it on the top cranked up the engine and swapped over screwdrivers....so 15g to play with......getting it to fly will be tricky then certainly vertically anyway....or can I get the card to fit withing 15 g???
