Entry 4: The Keyboard and Joystick
A project log for Aiie! - an embedded Apple //e emulator
A Teensy 4.1 running as an Apple //e
jorj-bauerJorj Bauer 02/19/2017 at 15:061 Comment
Continuing to ignore the software for a moment: time came to wire up the keyboard.
This turns out to be very straightforward, if a bit pin-intensive. I wanted all of the keys on an Apple //e keyboard. The joystick buttons are the same as the open- and closed-apple keys; those are to the left of the teensy. The rest are all right there: 13 columns and 5 rows. There's also a reset/menu button that's in the upper-right, unfortunately just under the LCD (it seemed like a good idea at the time).
The Apple //e couldn't handle multiple simultaneous keypresses. There was a dedicated processor for the keyboard, which loaded data in to the data bus for one and only one key at a time. But I don't know what else I'll do with this hardware, so I'd like to at least have it capable of multiple keypresses, even if the virtual Apple //e I'm building won't be able to take advantage of it.
The classical way to build such a keyboard would involve a lot of diodes. I had about 30 1n917s and 1n1418s that I could use, but I'd need about 65. I actually bought 100 more 1n917s, getting ready to solder them all in. And then I found the Arduino matrix Keypad library, which does something very clever! It uses the tri-state nature of Arduino I/O pins to scan the rows and columns to figure out what's pressed. Because it's pulsing each row/column, it doesn't need the diodes to separate the signals. Bonus - saved me a bunch of soldering time! Those diodes go back in the box for the next project that needs them, and I can safely say that I've still built this thing out of the parts in my house.
For a little while, at least. Until I broke the joystick.
The picture you see above has the cap missing from the joystick. That's not the problem. I'd actually lost the cap while it was on the previous project it had been part of; the joystick was still functional. And it made it in to this project fully functional for a while. Then one of the two axes started giving me garbage. Resoldering made no difference, and I bought a replacement from Adafruit... just to have the second one do the same thing after about a day.
Harrumph. Guess I need to find a better joystick.
Unfortunately, by this point I've kind of painted myself into a corner. The design assumes that the joystick fits in that space. I've now soldered the display in, so I can't easily move it up to buy some more. And I can only find two other joysticks that will potentially fit. Both, fortunately, carried by Adafruit.
They look pretty much the same: the Parallax 2-axis joystick and the Analog 2-axis Thumb Joystick with Select Button + Breakout Board. I bought one of each, and when they arrived, there were two issues.
First: the thumb joystick just doesn't fit. It hits the teensy on the left. It hits the LCD just above it. But you can take the joystick piece off, so I'll worry about that later.
Second: neither of the joystick bases fits as-is. The first has an adapter board soldered on to it, and the second has a button that hangs off the right side (making it too wide to fit on my board).
Rather than cutting the button off of the second and re-working its mechanics, I opted to desolder the first from its adapter board.
Which leaves the joystick cap problem: a little Dremel work to remove its base, and things fit pretty well!
"What about the MicroSD card?" I hear you cry. I got lucky here: the card - which you may be able to just amke out to the left of the joystick - *just* clears the joystick base. It's possible to get it in and out, but it's not something I want to have to do often.
The joystick's rotation is still slightly fouled by the LCD when trying to move it to the upper left corner. But it's manageable. If I were starting over, I would move the LCD up a hair; and the Teensy would probably go under the LCD, vertically, with the SD card popping out the top. Which would mean hard-mounting the teensy instead of leaving it socketed...
clae wrote 05/11/2019 at 09:59 point
Unless you mounted it on the back of the board
