Fully Assembled Transfer Block
A project log for WITCH-E Decimal Based Computer
Document and create a modern replica of the Harwell Dekatron computer known as the WITCH
daves-dev-labDave's Dev Lab 02/24/2017 at 21:250 Comments
I was able to complete the assembly of the transfer block last night. the transfer block includes the Transfer Unit, Carry Select, and Carry Unit. each of the modules are soldered together with wire between the 0.1" headers and mounted with M2 screws with 5mm brass standoffs....
