Soldering Sponge Automatic Water Dispenser
I got tired of the soldering sponge drying out. So I built an automatic water dispenser to "water" it.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The dispenser uses a sensor to measure the resistance of the sponge. If the sponge drys out too much the resistance goes up, microcontroller detects it and turns on the pump. I am using an arduino as the project is still in development. I'm planning to later replace it either with some microcontroller or simply an op amp. I am thinking about using a micro so there can be some error detecting mechanism programmed in. I don't want 3L of water to be emptied on the table if the sensor gets somehow disconnected.
