Currently developing an IoT dashboard that will monitor different locations. I needed a basement monitor that will monitor temp/humidity, carbon monoxide, and water on the floor. I am planning to add a simple oled display and motion detector that will enable the oled when it senses someone nearby.
Currently using a nodeMCU. The system will be device agnostic and will accept and HTTP Post request as long as its in the correct format. Eventually MQTT will be an option.
Status:
Software - 35% done, it works but needs create and settings pages.
Hardware - Waiting on parts :(
