Addressing the issues from the previous version.
- Separating of the of the debris collection and flow structures need to be more pronounced.
- Assembly need to be easier.
- Simpler design with lower part number without the need of solvent welding.
- Redesign for printing.
- Debris collection is easily accessible.
- Hoses need to be attached easier. (todo)
Separating the inlet stage and the cyclone stage the external shell forms the main chassis able to collect the larger particulates and hair, hair was a real problem. This also has been altered to make the assembly easier with all seven dust collectors serving the dual purpose of mechanical seal.
Assembly will be by screwing the collectors onto the base.
more
ok
The CAD will be released if the design works.
