~ hard- & softwareupdate ~
A project log for S3P ~ supercaps and solar panels ~
The powersolution for your trip to the wilderness!!
kirschner-christophKirschner Christoph 04/01/2017 at 17:072 Comments
Today I added two transistors to my prototyping-shield. Their purpose is to cut down the energy-consumption of the servo and the DC-motor, if their are not in use.
In order to get faster and better results I also did some coding.
Special thanks goes out to @Stefan-Xp who gave me a few really good advices. I hope the programming got a little bit better. :D
Here you can see the result:
#include <Servo.h>
Servo xServo;
int positionServo = 90; // Anfangsposition und Speicher für Gradstellung des Servos / startposition
//Pin-Belegung
int const DCMotorNegative = 8;
int const DCMotorPositive = 7;
int const endPosition1 = 6;
int const endPosition2 = 5;
int const movingOFF = 4;
int const powerServo = 3;
int const powerDCmotor = 2;
// Sensorwerte / values of the sensors
int valueLDR1 = 0;
int valueLDR2 = 0;
int valueLDR3 = 0;
int valueLDR4 = 0;
int valueTiltSwitch = 0;
// Präzision der Motoren / accuracy of the motors
int DCaccuracy = 5;
int servoAccuracy = 8;
//Endpositionstaster-Speicher / endposition memory
int endPositionState1 = LOW;
int endPositionState2 = LOW;
int lastEndPositionState1 = LOW;   // the previous reading from the input pin
int lastEndPositionState2 = LOW;   // the previous reading from the input pin
// Zeitkonstanten/ timevalues
long lastAdjustmentTime = 0;
long sleepTime = 60000;
long activeTime = 80000;
long lastDebounceTime1 = 0;  // the last time the output pin was toggled
long lastDebounceTime2 = 0;  // the last time the output pin was toggled
long debounceDelay = 30;    // the debounce time; increase if the output flickers
//Prädeklaration
void turnServo ();
void endPositionReading ();
void turnDC ();
void setup() {
  Serial.begin(9600);
  xServo.attach(9);
  xServo.write(positionServo);
  pinMode(A0, INPUT);
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
  pinMode(A4, INPUT);
  pinMode(A5, INPUT);
  pinMode(powerDCmotor, OUTPUT);
  pinMode(powerServo, OUTPUT);
  pinMode(movingOFF, INPUT_PULLUP);
  pinMode(10, INPUT);
  pinMode(11, INPUT);
  pinMode(12, INPUT);
  pinMode(13, INPUT);
  pinMode(DCMotorPositive, OUTPUT); // Pin 7
  pinMode(DCMotorNegative, OUTPUT); // Pin 8
  pinMode(endPosition1, INPUT); // Pin 6
  pinMode(endPosition2, INPUT); // Pin 5
  digitalWrite(powerServo, LOW); // schaltet Spannung ab / cuts down power
  digitalWrite (powerDCmotor, LOW);
void loop() {
  // 60s Schlafzustand, 20s aktiv/ 60s sleeping time, 20s active
  lastAdjustmentTime = millis();
  if ( (millis() - lastAdjustmentTime) > sleepTime ) {
    while ( (millis() - lastAdjustmentTime) < activeTime ) {
      // Anhalten der Bewegung, Messen der Kondensatorspannung / stopping movement, measure capacitor-voltage
      while ( digitalRead(movingOFF) == LOW ) {
        delay(1000);
        float voltage = 0;
        voltage = analogRead(A0);
        voltage = map(voltage, 0, 1023, 0, 5000);
        voltage = voltage  / 87 ;
        Serial.print ("Spannung:  ");
        Serial.print (voltage);
        Serial.println ("  V");
      //Auslesen der LDRs und des Kipptasters / reading of the LDRs and of the tilt switch
      valueLDR1 = analogRead (A1);
      valueLDR2 = analogRead (A2);
      valueLDR3 = analogRead (A3);
      valueLDR4 = analogRead (A4);
      valueTiltSwitch = analogRead (A5);
      turnDC ();
      turnServo ();
      delay(25);
void turnDC () {
  //Vergleichen von LDR2 und LDR4, je nachdem dann folgt Bewegung / comparing LDR2 and LDR4
  if ( (valueLDR2 - valueLDR4) > DCaccuracy ) {
    digitalWrite (powerDCmotor, HIGH);
    if ( endPositionState2 == HIGH)
    { digitalWrite(DCMotorPositive, HIGH);
      delay (10);
      digitalWrite(DCMotorPositive, LOW);
  if ( (valueLDR2 - valueLDR4) < - DCaccuracy ) {
    if ( endPositionState1 == HIGH)
    { digitalWrite(DCMotorNegative, HIGH);
      delay (10);
      digitalWrite(DCMotorNegative, LOW);
void turnServo () {
  int OldPositionServo;
  OldPositionServo = positionServo;
  //Vergleichen von LDR1 und LDR3/ comparing LDR1 and LDR3,
  if ( positionServo > 0 && ((valueLDR1 - valueLDR3) > servoAccuracy) && valueTiltSwitch < 100) {
    positionServo = positionServo - 1 ;
    DCaccuracy = 5;
  //Erhöhen der Genauigkeit des DC-Motors, wenn Servo bei 0° / increasing dc-motor accuracy when reaching 0°
  if ( positionServo == 0 && ((valueLDR1 - valueLDR3) > servoAccuracy)) {
    DCaccuracy = 1;
  if ( positionServo < 180 && ((valueLDR1 - valueLDR3 ) > servoAccuracy) && valueTiltSwitch > 1000) {
    positionServo = positionServo + 1 ;
    DCaccuracy = 5;
  // Erhöhen der Genauigkeit des DC-Motors, wenn Servo bei 180° / increasing accuracy of the dc-motor when reaching 180°
  if ( positionServo == 180 && ((valueLDR1 - valueLDR3 ) > servoAccuracy)) {
    DCaccuracy = 1;
  if  ( positionServo < 180 && ((valueLDR1 - valueLDR3) < - servoAccuracy) && valueTiltSwitch < 100) {
    DCaccuracy = 5;
  if  ( positionServo > 0 && ((valueLDR1 - valueLDR3) < -servoAccuracy) && valueTiltSwitch > 1000) {
    DCaccuracy = 5;
  if ( OldPositionServo != positionServo ) {
    digitalWrite (powerServo, HIGH);
    //Serial.print ("positionServo:  ");
    //Serial.println (positionServo);
    digitalWrite (powerServo, LOW);
void endPositionReading () {
  int reading1 = digitalRead(endPosition1);
  int reading2 = digitalRead(endPosition2);
  //Entprellen Endpositionstaster 1
  if (reading1 != lastEndPositionState1) {
    lastDebounceTime1 = millis();
  if ((millis() - lastDebounceTime1) > debounceDelay) {
    if (reading1 != endPositionState1) {
      endPositionState1 = reading1;
  //Entprellen Positionstaster 2
  if (reading2 != lastEndPositionState2) {
    lastDebounceTime2 = millis();
  if ((millis() - lastDebounceTime2) > debounceDelay) {
    if (reading2 != endPositionState2) {
      endPositionState2 = reading2;
  lastEndPositionState1 = reading1;
  lastEndPositionState2 = reading2;
  //Anpassen der Servo-Genauigkeit / increasing servo accuracy when reaching endposition switch
  if ( endPositionState1 == LOW || endPositionState2 == LOW ) {
    servoAccuracy = 1;
  } else {
    servoAccuracy = 8;
Stefan-Xp wrote 04/02/2017 at 18:29 point
Looks much better for me. Congratulations!
Kirschner Christoph wrote 04/02/2017 at 18:52 point
Thanks for your advices !! :)
