Just building a big scale plotter. I'll use it for making tailor pattern, later maybe laser cutting as well. Dimensions are around 150x110 cm. It'll be attached to my cutting table. The rails are hidden under the tabletop. Hope it'll look stylish and modern. This is a modified project of the CNC v2.1 made by Norbert Heinz,http://homofaciens.de/technics-machines-cnc-v2_1_en.htm
