An important step in components research
A project log for Sonar Blind Project
The Sonar Blind Project tends to replace the blind mans canes with a wristband that works with sonar concept.
sonar1Sonar1 03/23/2017 at 18:580 Comments
We have been struggling with the number of vibration motors we should put in our device, and we have decided that the most logical choice was to put 50 in it. Indeed, it would give us a 90 mm scale interval, which is pretty accurate, and we could even improve this accuracy by, for instance, setting 2 levels of vibration, which would give us a 45 mm scale level.
So the user will be able to detect the difference of distance between 2 objects that are 9 cm far (max).
