Log 8 : 05/12/2017
A project log for M.A.B
this project will be used to measure someone's respiratory rhythm via a bracelet installed on your arm.
mabM.A.B 05/29/2017 at 08:160 Comments
For the captor's code part we found successfully a code on github which will permit us to transform a photosensitive data to an analog data (wavenumbers, beats per minutes). In fact this code read "heart rate" data.
research source : https://github.com/sparkfun/SparkFun_MAX3010x_Sensor_Library/blob/master/examples/Example5_HeartRate/Example5_HeartRate.ino
