Log 11 : 05/29/2017
A project log for M.A.B
this project will be used to measure someone's respiratory rhythm via a bracelet installed on your arm.
mabM.A.B 05/30/2017 at 07:070 Comments
Today we found a new code which collect data on your heart rate and oxygen saturation at the same time. Meanwhile we didn't succed to make it work.
We cut our wires shorter for esthetic, then we soldered them again to the captor.
We tested the new code. Nevertheless the code is not working as we wanted. So we came back to our first program.
Tomorrow we will test a last time our device.
