Day 22: evezor_arm_v1_nano_sleeve_board
A project log for Evezor Robotics and Automation Platform
A Networked set Robotic Arms, Motion platforms, sensors and more. Easily programmed with a drag and drop interface.
anfroholicanfroholic 10/02/2023 at 05:440 Comments
This board was intended to sit at the elbow of the robotic arm and its primary function was to obtain and smooth readings from the encoders and to drive the neopixel arrays at each joint.
It also featured 2 ide ports that followed the Gadgeteer standard which I found to be a less than satisfactory attempt at creating modular systems. More on these reasonings can be found in some of my other posts.
source files can be found here: https://github.com/evezor/evezor_arm_v1_nano_sleeve_board
