21/04/2017
Today we are testing the temperature sensor , the turbidity sensor with their programs and they are both working ! There is a photo of the temperature sensor down below. We also add the codes we used for these components in the files of the project.
Otherwise we have some issues with the wi-fi module, indeed we need a server to make our proper network so we continue to work on it and we will make a post when we achieved to do it !
Finally we will test the GPS module next time , and we will keep you informed of the developments.
