Preliminary Update
A project log for 3D Printer Power Control Board
A super simple little control board that allows for connecting/disconnecting power from a 3D printer via a relay.
skellyskelly 03/25/2017 at 04:550 Comments
Everything is currently designed schematic-wise and all the parts are purchased/available. The only worry I have is that if the printer draws more than 5A of current, the relays I have are woefully inadequate. I'm using Omron 12V 5A relays for switching. I guess I'll find out depending on if the relay contacts get welded together or not!
