S2: The smallest General MIDI board in the world
Very small Waveblaster Compatible General MIDI board : 24mm x 34mm
Small waveblaster module, based on the SAM2695 chip.
- 64-voice polyphony (without effects)
- 38-voice polyphony + effects
- General MIDI compatible effects
- 4-band stereo equalizer
- Very small size, ideal for building into projects : 24mm x 34mm
http://www.serdashop.com/waveblaster
Here's a video review/demo by Phils Computerlab
Adapter for using S2 on DB15 Joystick/MIDI port
Portable Network Graphics (PNG) - 113.48 kB - 03/28/2017 at 16:56
Preview
Download
View all 6 project logs
  • 1
    Step 1
    Designed an adapter to use S2 with DB15 Joystick/MIDI port .
    Works fine !
View all instructions
serdef wrote 03/27/2017 at 16:57 point
yes it will work !
I also made a higher end card : http://www.serdashop.com/DreamBlasterX2
JL9791 wrote 03/27/2017 at 17:12 point
If I had more money and this was not my first retro PC, I would certainly get that.  All of your tech looks pretty cool :)  Good work.
serdef wrote 03/27/2017 at 17:28 point
thanks
JL9791 wrote 03/27/2017 at 16:48 point
Oh, cool!  I recently acquired an old PC (AMDk6) with some old ISA sound card (uses a Crystal sound chip) and it looks like it has the pins for this kind of device.  Would this likely work with it? Thanks.
