PID control
A project log for Affordable Exoskeleton Arm (ExoArm)
An affordable Exoskeleton Arm (ExoArm), that will help elderly, disabled people and workers complete everyday tasks with less exhaustion.
kristjan-berceKristjan Berce 10/20/2017 at 15:331 Comment
Here is a little test with PID control. As you can see it can hold a position pretty well. The PID is not tuned. That's why you can hear that beeping sound coming from the motor.
Now all I have to do is to join PID control with intuitive movement, so that I can actually lift something.
This video is without any regulator/power:
Here you can see PID regulator in action. It is designed so that it holds a setpoint (angle), and tries to do that no matter whether there is a force on it or not)
martinez wrote 06/19/2018 at 08:32 point
1.hola que tal espero que bien. tengo unas dudas una es que el programa no me carga al adruino :( ayuda
