Less copper, more enginuity
Reduce high direct current cables in 12V systems by using overlay communications
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The aim is to design a low cost and small form factor switches, to control 12VDC appliances.
In boats, caravans and other 12V DC systems, there is requirement for a thick copper wiring, to power on board appliances. And with more complex systems, the amount of wiring adds up to a very considerate amount of money. The idea is to replace all the wiring to a single pair of adequate thickness copper wire. To control the appliance power (ON/OFF) a high frequency overlay would be used with micro controller controlled master-slave topology switches.
