Exposing sensor for cooling
A project log for Cool my CCD
Is it worth cooling digital camera sensor? (Actually CMOS)
deepsoicDeepSOIC 03/30/2017 at 19:510 Comments
The camera was like made for being hacked. Look!
Its sensor board is right against right-hand-side wall, and it has a copper heatsinking/spreading/shielding plate on top! So all I had to do was to dremel out a hole in the wall, and seal up the gaps with silicone caulk. Awesome...
Then I attached a thermocouple
Next, I turned a heat transfer copper peg on my lathe
and superglued it to the sensor plate.
Almost ready to go! Next up, sealing (which happened in parallel, but I separate it into a new project log).
