The main DC/DC converter
A project log for Tusotek DC/DC Boost - Constant Current
How to modify the low-cost "Tusotek 200W DC/DC Boost Converter module" to be a Constant Current controlled converter (boost LED driver)
benjaminaignerbenjaminaigner 04/01/2017 at 13:200 Comments
The heart of this module is a FP5139 Asynchronous Boost Controller.
It's packaged in TSSOP8 and has different features we have to deal with:
Basically, this booster module is designed like the Application Information in Figure 14 of the FP5139 datasheet.
Some minor modifications compared to this app note:
If you look at the picture, following colors correspond to these parts of the app note:
orange: FP5139 chip
yellow: Q1/Q5 totem-pole / push-pull gate driver
pink: MOSFET & Diode (Q2/D2)
blue: voltage limiter (some kind of transistor circuit)
green: feedback circuit filter capacitor and R6 in the app note (lower side of a voltage divider)
turquoise: oscillator settings & soft-start capacitor
red: feedback pin, that's what we need
BTW: The MOSFET was destroyed by me (while removing the heatsink), so your boost module might look different :-)
