Design considerations
A project log for Mouse Aid
With this companion your mouse will be able to perform fine and precise movement in drawing applications
danjovicdanjovic 04/02/2017 at 20:500 Comments
The Digispark is a cheap and easy board to build USB devices, but the original circuit suffers from some unlucky design choices:
The three issues above makes the life harder when you aim for a minimalist design like in the present project, but let's pour the cards on the table:
As for the resources:
And the limitations
Now the demands for this project
Easy Peasy!!
