Boards built
A project log for Two-handed chording keyboard
Filling the vacuum in high quality chording keyboards market.
ptravptrav 04/05/2017 at 07:550 Comments
Initially three boards were built: one for the thumbs and two for the fingers.
As the project is experimental, I decided to make separate components - with electrical connectors and M3 bolt holes. The pre-drilled "line" PCBs with 2.5 mm holes fit perfectly to the selected button size.
For each button, three PCB holes should be expanded, and one additional 1 mm hole drilled through the trace. The latter is tricky to do with the classic electric drill, so I've used a high-speed Dremel (wear eye protection!)
The PCB drawings are as following:
1. Left finger board
2. Right finger board (a mirror image of #1, but pins are different)
3. Thumb board
The schematics is as following (the standard approach for Arduino keyboards):
Note the diodes protecting from the false closures.
The operational mockup looked as below (the original mockup board was used for the base):
