We have an example!
A project log for Switchboard: Distributed Automation made Easy
A small Python framework for the tinkerer to make distributed automation as simple as possible
josefschneiderjosefschneider 04/25/2017 at 21:080 Comments
I managed to fix a bunch of bugs to do with functionality I hadn't run in a while, and have also added a simple example showing the absolute minimum required to get a Switchboard setup working. The example files consist of an input client, an output client, a test module that simply multiplies the input, and a settings file so that everything is ready to go.
The one things missing here is a list of commands (which I shall be adding to the readme shortly), but the command line interface comes with '-help' functionality and tab-completion and is rather simple.
Next steps:
