made panelized PCB board
04/18/2017 at 16:36 • 0 commentsTo save cost, i have put 4 boards into 127mm x 73mm area but its not very cost effective yet.
I plan to adjust 4 boards into 100x100mm area later.
Gerber files are at https://github.com/amitesh-singh/FASTUSBasp/tree/master/kicad2/pan-gerber
kicad design completed
04/18/2017 at 15:03 • 0 commentsfinally i am able to complete the kicad design of FASTUSBasp adapter board.
The latest kicad files and gerber files can always find at.
firmware coding has been completed.
04/15/2017 at 10:29 • 1 commentWell, i am done with writing firmware coding. The results are quite good.
The latest code can be always find out here.
Next target is to develop an adapter board so that you just plug and place blue-pill board on it and start flashing AVRs.
$ sudo avrdude -c usbasp-clone -p m16 -U flash:w:ST7735.hex [sudo] password for ami: avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.00s avrdude: Device signature = 0x1e9403 (probably m16) avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "ST7735.hex" avrdude: input file ST7735.hex auto detected as Intel Hex avrdude: writing flash (4200 bytes): Writing | ################################################## | 100% 0.28s avrdude: 4200 bytes of flash written avrdude: verifying flash memory against ST7735.hex: avrdude: load data flash data from input file ST7735.hex: avrdude: input file ST7735.hex auto detected as Intel Hex avrdude: input file ST7735.hex contains 4200 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 0.08s avrdude: verifying ... avrdude: 4200 bytes of flash verified avrdude: safemode: Fuses OK (E:FF, H:D8, L:CF) avrdude done. Thank you.
Write speed:>>> 4200/0.28 = 15KBps
Read Speed:
>>> 4200/0.08 = 52.5 KBps
This is quite nice!
