Video of the system
A project log for Modular Low Cost RGB LED Cube with QT/GL simulator
A RGB LED Cube that can be built with cheap and easy to solder hardware, that is modular and scalable and that has a rich user interface
timTim 04/25/2017 at 23:260 Comments
I created a short video of the LED Cube with the GUIs in action. At the beginning you can see how the client application can play algorithms on the cube. Then it is shown how the cube color can be set from within the application (It is not shown how single LEDs can be switched. I will probably show this in another video). Finally The Webbrowser of a Tablet is used to control algorithms on the Cube itself without using the client application.
Enjoy!
