Fitting foam
A project log for Peliputer
Lug-able ATX workstation and monitor in hand luggage sized Pelican case
david-brownDavid Brown 04/24/2017 at 20:500 Comments
The case is lined with lightweight anti-static, rigid polyethylene foam, held in place by 3M 90 high strength spray adhesive. Which is reasonably good at adhering to the plastic of the pelicase.
Pelican are good, in that they supply CAD models for the inside cavity of their cases, this makes designing much easier, producing less errors.
Masking out the areas for the spray adhesive
Counter coating the foam pieces, only the side pieces are bonded to the case
Side pieces fitted
Base installed
