• Second Version
    Richard Deininger04/26/2017 at 07:03 0 comments
    So I made a second version,... this time I filpped the stencil... and also a little bit deeper.
    Also this time I documented the etching part,.... but not the testing :)
    But here you'll see my setup.
  • First Version
    Richard Deininger04/26/2017 at 07:00 1 comment
    The first version was made pretty quick and had all the major compnents.
    I used an old metal stud I had laying around, cut it, sanded it, drilled it, threaded it and finally made a handle for it. Not to mention the etching part.
    And then after some testing I found that I had to horizontaly flip the stencil (duh).
