• 1
    Step 1
    The circuit diagram of the project:
  • 2
    Step 2
    Project coding in code composer studio:
    #include "msp430.h"
    #define ADC_CHANNELS 2
    unsigned int samples[ADC_CHANNELS];
    #define LED1 BIT4
    #define LED2 BIT6
    #define SENSOR_LEFT BIT0
    #define SENSOR_GND BIT2
    #define SENSOR_RIGHT BIT1
    #define SENSOR_GND1 BIT3
    #define RED_LED LED1
    #define GRN_LED LED2
    void ConfigureAdc(void){
    ADC10CTL1 = INCH_1 | ADC10DIV_0 | CONSEQ_3 | SHS_0;
    ADC10CTL0 = SREF_0 | ADC10SHT_2 | MSC | ADC10ON | ADC10IE;
    ADC10AE0 =SENSOR_LEFT + SENSOR_RIGHT ;
    ADC10DTC1 = ADC_CHANNELS;
    void main(void) {
    WDTCTL = WDTPW | WDTHOLD;
    BCSCTL1 = CALBC1_1MHZ;
    DCOCTL = CALDCO_1MHZ;
    BCSCTL2 &= ~(DIVS_3);
    P1DIR = 0; /* set as inputs */
    P1SEL = 0; /* set as digital I/Os */
    P1OUT = 0; /* set resistors as pull-downs */
    P1REN = 0xFF; /* enable pull-down resistors */
    P2DIR = 0; /* set as inputs */
    P2SEL = 0; /* set as digital I/Os */
    P2OUT = 0; /* set resistors as pull-downs */
    P2REN = 0xFF; /* enable pull-down resistors */
    P1REN &= ~(LED1 | LED2); /* disable pull-up/downs */
    P1DIR |= (LED1 | LED2); /* configure as oututs */
    P1REN &= ~(SENSOR_GND |SENSOR_GND1); /* disable pull-up/down */
    P1OUT &= ~(SENSOR_GND|SENSOR_GND); /* SENSOR_GND should be at GND */
    P1DIR |= (SENSOR_GND |SENSOR_GND1); /* SENSOR_GND must be an output */
    P1REN |= (SENSOR_LEFT|SENSOR_RIGHT); /* enable pull-up on SENSOR */
    P1IN |= (SENSOR_LEFT|SENSOR_RIGHT); /* set resistor as pull-up */
    ConfigureAdc();
    __enable_interrupt();
    while (1) {
    __delay_cycles(1000);
    ADC10CTL0 &= ~ENC;
    while (ADC10CTL1 & BUSY);
    ADC10SA = (unsigned int)samples;
    ADC10CTL0 |= ENC + ADC10SC;
    __bis_SR_register(CPUOFF + GIE);
    if (samples[0] < samples[1]) {
    P1OUT |=RED_LED;
    P1OUT &= ~(GRN_LED);
    } else if (samples[0] == samples[1]) {
    P1OUT &= ~(RED_LED);
    } else {
    P1OUT |= GRN_LED;
    #pragma vector=ADC10_VECTOR
    __interrupt void ADC10_ISR (void){
    __bic_SR_register_on_exit(CPUOFF);
