Dem wheels & sprockets
A project log for Dangercycle
When a tricycle meets a lawnmower engine and two crazy chaps
frdric-druppelFrédéric Druppel 05/07/2017 at 09:330 Comments
After a late, long chat with Manoel about which wheels we where going to use, we found some interesting links to where we could buy some.
Here they are (I also posted them for us in case we forget them) :
1st idea https://www.befr.ebay.be/itm/300919651560
2nd idea https://www.befr.ebay.be/itm/370376940748
3rd idea https://www.2ememain.be/auto-pieces-accessoires/pi%C3%A8ces/ligier/ligier-js6-pi%C3%A8ces-divers-aussi-300528328.html
4th idea https://www.amazon.fr/dp/B01N5HPB9P/ref=cm_sw_r_cp_api_ztTdzb2RNPE28
The 4th one is probably the one we'll end up using, as it's cheap and, well because it's cheap.
For the sprockets, we'll firs search in a scrapyard or something, but of we don't find anything, we'll probably buy some of those : http://www.befr.ebay.be/itm/35-Chain-Sprocket-9-10-11-12-13-14-15-16T-Pitch-9-525mm-For-3-8-35-06B-Chain-/152473406789?var=&hash=item23801f8d45:m:mYVo2KnvnOnbpvRAAwq5r4Q
The shaft diameter will most probably be 20mm
That's all folks !
