Testing Harness
A project log for Landy Wiper Control
Sick of having 2 speeds for my windscreen wipers. Nothing a 555 timer can't fix!
tron9000Tron9000 05/27/2017 at 20:340 Comments
Went and tested the harness and a number of issues and faults
  1. Had wrong connectors on end of harness to mate with connector
  2. Blew fuse for washer pump. Replaced fuse and tested pump again by shorting GRN-Blk to GND and not working so washer pump is probably FUBAR'd - fantastic... then realised I was driving the pump with 12V instead of pulling it down. Bellend!
  3. Tried the wiper functions and did not get any satisfactory results and blew a fuse for the wiper motor in the process.
So in summary I need to go back to the drawing board, give me head a shake, and try again!
