New PCB clearence
A project log for Debug Board Isolator
Simple, tiny USB to UART converter, also with a galvanic isolation
saimonSaimon 05/29/2017 at 12:450 Comments
Unfortunately we discovered a problem with the PCB layout.
The clearance was not meeting the requirement for the high voltage insulation.
For this reason we made a new PCB layout with 4mm clearance, enough for isolating up to 1kV.
