Loading instructions from memory, now with PCBs
A project log for JACA 1 & 2 Homebrew Computer
JACA - Just Another CPU Again Homebrew CPU, starting by a simple POC 4-bit CPU on circuit simulator soft. (done), then 8-bit (in progress)
andre-baptistaAndre Baptista 11/20/2018 at 23:490 Comments
I connected two modules that are now converted to PBCs, the Clock and the Instruction Register. Between them is the Program Counter and Memory, still in a breadboard. This is the last module I plan to turn into PCB.
Everything worked fine, despite some stupid mistakes I made (these chips don't fry easily).
This video shows the modules working together:
Thanks for reading and see you next time.
