Size matters
A project log for Progmeter
What happens when you combine crappy multimeter and poor programable calculator?
jaromirsukubajaromir.sukuba 08/19/2014 at 14:110 Comments
Seems like I spoke too soon about the display and keys.
Jelly-bean 6x6mm keys do have quite big footprint and I can place four of them into width of 55mm, which was my personal limit of width. Display is quite big as well, so I have to make the board 57mm wide.
Well, I'm going to think about the dimensions and components again; I have to maek decision whether to use common components or keep the physical dimesnions small.
By the way, I set up github repo for this project and I'm uploading there work as it progresses.
