China cheap MP3 player hack
I want to hack cheap china 2 dollar MP3 player. Next step is design my own small dev board with STM32 and put it into original package.
LCD library (for STM32F0): https://github.com/dambo1993/universal_lcd_stm
Project on github: https://github.com/dambo1993/chinaMP3hack
My blog page: http://projektydmb.blogspot.com/
TODO list:
  • dissassembly - DONE!
  • LCD hack - DONE!
  • eagle PCB templata - DONE!
  • design simple PCB board with STM - in progress
  • Some basics project:
    • voltmeter
    • temperature datalogger
    • PWM parameter measure
    • maybe IR remote
  • PCBs!!!
    dambusio06/13/2017 at 18:44 0 comments
    Today I receive my package:
    Some errors ( :( )
    - wrong position of LCD pads - should be more in right and down position
    - soldermask on "buttons" - but I can easy fix this
    - a little different pinout to jack plug, but it is still ok to solder
    Quality of PCB - GREAT! :)
  • STM32F0 dev board
    dambusio05/26/2017 at 11:20 1 comment
    Unfortunately - only one output pin (on jack), but we can also use SWDIO and SWCLK. Order from China so I need to wait 3-4weeks to test it.
  • Eagle PCB template
    dambusio05/25/2017 at 00:17 0 comments
    I've created schematic and board with all important elements on its positions:
    Eagle files: https://github.com/dambo1993/chinaMP3hack
  • Hack a LCD
    dambusio05/25/2017 at 00:08 1 comment
    The most valuable from this device is of course LCD. But first I didn't know what controller is in it.
    Simple debug connections:
    Problem with connection to saleae:
    At this point I can copy value from uc to LCD and retransmit it, buf then I've found this site:
    http://overskill.alexshu.com/cheaphack-a-2-5-chinese-mp3-player-for-its-128x64-mini-lcd/
    with explanation about LCD type. It is UC1701. We cen use arduino library u8glib to play with it.
    As display PCB I use universal board for uC:
    So I can easy connect LCD to breadboard.
  • MP3 Player dissassembly
    dambusio05/24/2017 at 23:54 0 comments
    What can we find in 2 dollars MP3 Player:
    - nice custom package
    - graphic lcd (uc1701) 128x64px
    - Li-Po battery (I think ~100mAh)
    - USB connector
    - Jack 3.5mm connector ( Mouser #161-3334-E )
    - SD card slot
    - on/off switch ( https://www.sparkfun.com/products/10860 )
    - membrane keyboard
    - asic for mp3 player (I think useless)
    For 2 dollars!
View all 5 project logs
fabian wrote 07/19/2018 at 15:55 point
piekne, czy dało by się wstawić mocniejszy sprzęt? M0 lub nawet linuxa?
Jarrett wrote 03/02/2018 at 17:29 point
I just got mine in the mail!
Are you planning on fixing the positions of things on the PCB and then releasing a new version?
Mary T. Naylor wrote 03/11/2021 at 13:01 point
is this doing same as this website https://ytformp3.com
