So there is a lot of information out there on the internet about controlling ESCs but there doesnt seem to be one place where all the useful information is gathered. This is a little project of mine to help teach me and possibly (if it goes well) others in the process.
1×
Arduino Uno
It is possible to use many different devices this is probably one of the hardier ones. It was on the bench when I started the project so thats what I went with
1×
Misc connector wires
For signaling and power connections
So as it turns out I'm just starting on this project but had a few things already laying around from other half finished projects that will hopefully tie in quite nicely with this one. One of the secondary goals of getting this project up on hackaday.io is to try and motivate me to actually finish this project and hopefully a decent amount of information, documentation and guides on it as well. The writing up of projects is a particular pitfall of mine.
I've went ahead and added some things to the components list which are necessary or useful to have. There are some things that I won't add tool wise like multimeters, soldering equipment ect. but I will mention it when I use them as I go in the project log.
hi, have you successfully connect Arduino with 120a esc?
