Nakano, K., et.al.(refs below) describe two versions of a small stack machine suitable for implementation on an FPGA and they give the Verilog source code on their web site. The design was ported to the DE2 board and extended to have a richer set of opcodes and i/o ports. I wrote a simple assembler and compiler for the architecture and implemented serial communication routines. The compiler supports inline macros, functions, one dimensional array variables, and the usual if-then-else-endif and while-do-endwhile structured programming. Supplied functions allow you to send and receive integers to the serial interface and to send points, strings and integers to the VGA.
A simple compiler, named Syrup, was written in matlab (also runs in Octave) to make programming easier. A source code is assembled into a Altera mif file, which can be read by the ram block. The link between the mif file and the Pancake cpu ram block is implemented with a synthesis directive in the same statement as the memory declaration and before the semicolon which terminates the declaration.
reg [DWIDTH-1:0] mem [WORDS-1:0] /* synthesis ram_init_file = " test_stack_machine.mif" */ ;
Three processors were hooked up to SRAM to control the VGA. A hardware SRAM memory multiplexer was built to give priority to reset, then to the VGA controller, then each of the three cpus. The source code has to signal that it wants SRAM access, then wait for SRAM available, then read/write and then signal completion. SRAM access is interleaved between the VGA controller and the three cpus. The VGA controller gets access on every VGA clock high, while the cpus share every VGA clock low. This works because memory is being clocked twice as fast as the VGA clock. On every VGA clock high, an address is set up based on the VGA address generator. On the VGA clock low, the SRAM data for the VGA is buffered into a register, while the address for the cpu read/write is set up. On the next VGA clock high, the SRAM data is buffered into a register for each cpu, while the next VGA controller read is set up.
A ROM character generator for VGA was built, based on the data from ECE 320 at BYU. The file from BYU is here, and the matlab program to convert it to an Altera mif file is here, and the mif file is here. The ascii character code is multiplied by 16 to from the base index for a character. The data at the base index location is the top byte (of 16) of the character image. The high order bit of the byte is the left-most pixel of the top line of the character. The ROM was connected to i/o ports on the stack processor, cpu 1, where a small routine reads the ROM and outputs colors to the VGA SRAM interface.
The SRAM interface to the VGA display actually has over 100,000 unused bytes which are not displayed, but the unused memory is in small chunks. The biggest piece of available memory is from address 246,400 to 262,144, or about 16 kbytes. These unused locations can be used to share non-graphics data between processors. We need 16-bit read/write functions and a mutex to lock memory. The SRAM switch used in the graphics functions above was extended with new functions to allow 16-bits to be written (the graphics interface writes only single bytes). The mutex is implemented using hardware test-and-set, clear, and read instructions. The hardware switch prioritizes memory access first, then mutex operations. On the processor side, the program must: (1) set up an sram read, write, or mutex operation, (2) assert a request, (3) wait for access achnowledgment, (4) do the read/write (5) de-assert request.
References:
Nakano, K.; Ito, Y., Processor, Assembler, and Compiler Design Education Using an FPGA, Parallel and Distributed Systems, 2008. ICPADS '08. 14th IEEE International Conference on; 8-10 Dec. 2008 pages: 723 - 728 (Nakano, K.; Ito, Y.; Dept. of Inf. Eng., Hiroshima Univ., Higashi-Hiroshima, Japan)
Nakano, K.; Kawakami, K.; Shigemoto, K.; Kamada, Y.; Ito, Y. A Tiny Processing System for Education and Small Embedded Systems on the FPGAs, Embedded and Ubiquitous Computing, 2008. EUC '08. IEEE/IFIP International Conference, Dec. 2008 pages: 472 - 479
John S. Loomis, Digital Labs using the Altera DE2 Board, http://www.johnloomis.org/digitallab/, Electrical and Computer Engineering, University of Dayton, Dayton, OH 45469-0232
