Converting an old hard drive into a magnetic stirrer.
So this project has been dead for a while, I just haven't been updating it.
Reason being, hard drive motors are completely unsuitable for this application. They are simply not designed to spin at low enough RPMs to perform this task, and therefore the project will not work at all.
That's part of learning! Thanks for reading!
I get the motor spinning and sorta plan out how the project is going to work, check out my write-up here or check out the video below!
