Breakout connector for the Motorola Lapdock for use with an array of devices
The users over on the Raspberry Pi forum and YouTube have discovered that shorting the sense pin to +5V turns the Lapdock on! Currently looking into creating a custom cable for it, the current one is extremely fragile
I have successfully pulled apart the lapdock and checked what each of the large ICs on the main board are. A full list of those and what they do is available on my website: http://kicodora.com/diy/11-motorola-lapdock-500-teardown-and-analysis
It would appear the problems that we are having (not accepting any input) is either related to HDMI CEC or HDMI HDCP
View all 2 project logs
Andrew Mitz
Gergely Imreh
Martin Ferreira
Rob Crouthamel
Yes, delete it Cancel
You are about to report the project "DockOut", please tell us the reason.
