There's a sensor sending data to the ESP8266. That data needs to be transmitted to a web server, process that data, and make a visualization based on that data.
Step 1: set up the ESP client software
Step 2: set up the node.js server software
Step 3: marry the client code with the sensor code
Public IP: Google what's my public IP and it will be first result
Private IP: on Mac, it is in Network Settings, right at the top
