Beginnings of transparent communication
A project log for Chirppp, Serial over LORA
Use LORA via GPIO and a full-duplex serial emulator for serial a connection intended for extended range use.
dominic-demarcoDominic DeMarco 07/25/2017 at 03:090 Comments
I've begun working on the actual program flow to send data through the serial ports seamlessly.
Here is the flowchart I've thought up for the initial design.
It's a big ugly, forgive me. But as you can see from the flowchart, I'm trying to keep the logic between the communicators the same. The only difference between the "client" and "server", is one starts at the "Receive data" stage, and the other starts at the "Read from serial and send packet" stage.
I did a quick implementation of this in a dirty state machine, and here are the issues I've had thus far that I need to look into fixing/improving:
Other than that, I think this a good basis for my design for v1 of chirppp, once I fix any bugs that rear their ugly head, of course.
If anyone is actually reading these, and likes to minimize program flows in their spare time (not judging), I'd love to hear any ideas on a flow that won't lose or accidentally duplicate packets, or if you spot any problem areas in the flow above, please let me know!
