V-Slot based CO2 Laser Cutter
Lasercutter, CO2, V-Slot, OpenBuilds
This a WIP:
Currently I have a DIY lasercutter made from 25x25mm Alu tubing - as an upgrade I ordered some v-slot that should arrive next week, this will then begin the build of my V2 laser
This build will be continually updated: As is, the BOM is proven so you can start ordering if you'd like to...
Submission log:
10 Aug 10AM - uploaded version of Sketchup file with the corner brackets, laser PSU, Brackets for the stepper motors, mounting brackets for the laser tube. mounts for the Driveshaft (8mm shaft running through F608Z Bearings)
10 Aug 10:15: Uploaded a PDF invoice of what I paid for the SDZ laser parts
10 Aug 12:30: Added renders to Build Instructions (Draft) - pending delivery of VSlot to verify and take better pictures of each step
2 Aug: Added Driveshaft, Y carriage belt mounting and tensioner, Lid and optimised placement of X rail to prevent damage to laser head and maximise cutting area
16 Aug: Added uprights to mounfirewall
DIY Lasercutter: Budget orientated, medium sized (60-100w), safety first, based on Lasersaur software toolchain
  • Progress:
    open hard warecoza08/19/2014 at 06:02 0 comments
    • 9 August 2014: Created project
    • 10 Aug: 2AM - uploaded version of Sketchup file with the frame added, as well as motors and 24v PSU
    • 10 Aug 10AM - uploaded version of Sketchup file with the corner brackets, laser PSU, Brackets for the stepper motors, mounting brackets for the laser tube. mounts for the Driveshaft (8mm shaft running through F608Z Bearings)
    • 10 Aug 10:15: Uploaded a PDF invoice of what I paid for the SDZ laser parts - in reply to request from discussion page.
    • 10 Aug 12:30: Added renders to Build Instructions (Draft) - pending delivery of VSlot to verify and take better pictures of each step
    • 12 Aug: Added Driveshaft, Y carriage belt mounting and tensioner, Lid and optimised placement of X rail to prevent damage to laser head and maximise cutting area
    • 16 Aug: Added uprights to mount firewall between cutting area and rest of machine (to allow for vacuum chamber to exhaust smoke). Validated corner brackets match mye existing sketches to ensure count is correct
    • 16 Aug: Updated BOM to most current state, should now be 99% complete - at least in regards to parts to order from OpenBuilds.com, Lightobject.com and SDZLaser.com. May need some extras sourced locally
View project log
  • 1
    Step 1
    Go to
    http://www.openbuilds.com/builds/v-slot-co2-laser-60-100w.1001/  and follow the directions
View all instructions
georgefomitchef wrote 04/30/2016 at 20:19 point
Hi man!
Want to show you  some our  videos.
Realy want to know your objective opinion!
Please skype me :george.fomitchev  or   mail me: gf@endurancerobots.com  if  you will decide to tell me something.
Thanks!
Video tutorials how to make your own diy laser engraving / cutting machine.
Video 1: How to assemble MakeBlock XY plotter.
 Video 2 : How to assemble DIY engraver.
