Start improving the product
A project log for Bracelet for the blind
The solution is leveraging from the available stuff, affordable.
tiendoTiendo 08/20/2017 at 19:480 Comments
Thank you to the judges, who chose my project for the Best Product category.
I will start implementing the list below and make 3 copies of the product to send to the judges.
- Improved circuit diagram:
   + Replace Relay 3v3a with Mosfet 4N60C.
   + Use the voltage boost module (3.7V --> 7V). Used to power the Arduino pro mini.
   + The device automatically turns off the power when the voltage on the battery is less than 3.6 volts. (The device works well when the battery has a voltage greater than 3.6 volts).
   + Add 2 buttons " + , - " Used to set, increase or decrease the volume of Buzzer or vibrating motors. (Save settings to EEPROM).
   + Charge time (Poli 3.7v 300mah): From 3.6v to 4.2v is about 40 minutes.
- Edit program.
- Led on the front to catch the attention of the opposite person.
- Improved wrist strap more flexible, more comfortable.
- Add alarm function (Acts as an alarm device in the house. If there is a moving object it will emit sound).
