Hall effect based Throttle
A project log for SMART SOLAR VEHICLE
Bringing sophisticated safety features in to economic class vehicles with an advantage of zero carbon emission.
vickyeee360vicky_eee360 07/19/2017 at 04:110 Comments
First throttle with potentiometer to vary the input reference voltage to the controller dedicated to the motor from 0-5v. The efficiency of speed variation and acceleration was not upto the mark as some lag is produced due to the significant voltage drop at the throttle. The acceleration was not satisfactory.
Now we have installed a throttle that work based on the Hall effect principle. This has increased the acceleration rate to the pressure applied on the pedal. Efficiency of acceleration is increased as the system consist of IC and a magnet. This system also reduced the size of the throttle pedal
